This command controls the way the hardware filters are installed for VXLAN ARP suppression.
| iparp | Selects IP ARP. |
| suppression | ARP suppression. Requests may be proxied. |
| filters | Control the way ARP suppression hardware filters are installed. |
| per-port | Install ARP suppression hardware filters on a per-port basis (default). |
| per-vlan | Install ARP suppression hardware filters on a per-VLAN basis. |
By default, per-port option is assumed.
The following example sets IP ARP suppression filtering per-VLAN:
configure forwarding iparp suppression filters per-vlan
This command was first available in ExtremeXOS 22.3.
This command is supported on the ExtremeSwitching 5420, 5520 series switches, and stacks with 5320, 5420, 5520, 5720 slots only.
